Theoutdoorsman
- Mar 6, 2003
- 676
When I tilt the outboard all the way up (or any height above full trim) the tilt cylinder will not hold the outboards weight. It will slowly fall until it meets the trim cylinders, at which point it will hold. I need to check the fluid level to rule that out. Is this the fill screw for the system? I'm pretty sure I know the answer. I would just like to be sure before randomly turning screws. I'm assuming it's full when it runs out the top with the outboard at full tilt, correct?
